I will use DOS Command "COMP file1 file2 /L > resultfile" and check the resultfile.
"COMP /?" shows other options...
FUKUI Yutaka
----- Original Message -----
>From: "Schlieker, Reiner" <reiner.schlieker@siemens.com>
>To: VRF <vrf@agilent.com>
>Subject: RE: [vrf] Difference of 2 files
>Date: Tue, 6 Nov 2007 13:55:55 -0500
>I use a utility called examdiff, there are others available. You are
>comparing the two .vee ascii files though, so you do have to have some
>understanding of how they are structured.
>Reiner
>-----Original Message-----
>From: Mairs, David [mailto:david.mairs@hp.com]
>Sent: Tuesday, November 06, 2007 1:45 PM
>To: VRF
>Subject: [vrf] Difference of 2 files
>To All,
>I am looking for a method to do a "diff"(UX term) between 2 files, is
>there a technique For this using VEE? I am looking only for the
>different lines between 2 files.
>Thanks,
>Dave
>You are currently subscribed to vrf as: reiner.schlieker@siemens.com To
>subscribe please send an email to: "vrf-request@lists.it.agilent.com"
>with the word subscribe in the message body.
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at
>"http://www.vrfarchive.com/vrf_archive".
>Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>with
FUJITSU ???(?)????[?9-433] ?????????
?????????·???????? ? ?? ? (FUKUI Yutaka)
INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
TEL: 044-754-2238(ext:711-5-3153) FAX: 044-754-2434(ext:711-5-3178)
FUKUI Yutaka
>Reiner
>To: VRF
>To All,
>Thanks,
>Dave
>with
I am looking for a method to do a "diff"(UX term) between 2 files, is there a technique For this using VEE? I am looking only for the different lines between 2 files.
Dave
