This may be a calling convention issue. If you put __stdacll in you Vee header file, Vee will do the right thing as regards function name decorations, so your header file would have a line like 'long __stdcall funcName(long arg1, long arg2, long arg3)'. You can tell if a function has been exported with the stdcall convention if the function name is followed by a string that looks like '@12' when running dumpbin. The '@12' tells you that the function has arguments taking 12 bytes of stack space.
Here's a link to a paper that may help:
http://www.sonic.net/~doomer/WhitePapers/forward/forward.html#calling_conventions
From: Shawn Fessenden [mailto:shawn@vrfarchive.com]
Sent: Thursday, January 31, 2008 6:52 PM
Subject: RE: [vrf] DLL runtime error
> Function was not loadable: startupXgd
The issue is the function is not called startupXgd. It will of course depend on exactly what the project settings are in VS for this dll, but my first guess would be "_startupXgd@0".
To prevent guessing, run dumpbin /exports <dllname>. If you don't have ready access to dumpbin, you can use Depends and look for the function name.
ftp://ftp.vrfarchive.com/pub/Depends.zip
Using "extern C" isn't good enough, as _stdcall function names are always decorated. The easy way to generate absolute names for export is to use a .def file with an EXPORTS section.
-SHAWN-
-SHAWN-
