Any ideas of where to look for sample PID control code written in VEE?
I should not be lazy and go look I assume I can write C or Basic inside a VEE function box using DO loops and If/then etc. but I've never tried it.
I need to store some global variables so that the algorithm can use them after each reading of the item to be controlled.. not sure about that either.
This is probably the dumbest question for the day..
Thanks
-hc
Thanks
-hc
