Has anyone found a way to include non-rectangular shapes or images in VEE? I'd like to use an animated pointer for instructions, but would like to do it in a way that doesn't resemble PONG.
Lorne
_____
The information contained in this message may be confidential and legally protected under applicable law. The message is intended solely for the addressee(s). If you are not the intended recipient, you are hereby notified that any use, forwarding, dissemination, or reproduction of this message is strictly prohibited and may be unlawful. If you are not the intended recipient, please contact the sender by return e-mail and destroy all copies of the original message.
You are currently subscribed to vrf as: hua_jing@agilent.com
Lorne
_____
I was searching the vrf archive and found there is a fromTouchstone function but I can't find that in vee 7.5.
I need a function which will read in a touchstone file and allow for nay number of ports. Usually we work with 8 or 16 ports. Has anyone already got a function to read a touchstone file into vee?
Thanks
Jacob
