Hi
First of all - Merry Christmas to all of you.
I have a program that will "only" be used once or twice each month.
PC clocks are reliable but not exact – so I need an object that can update the PC clock so that the data logged will in “real” time.
Maybe even with the local offset to GMT.
Regards
Steen Rudberg
Low Mountains Railway
http://www.5inch.dk
Regards
Steen Rudberg
http://www.5inch.dk
The time on your PC is sync with online servers that you can change in your PC.
It sync once a while, then it start using internal clock to count the clock. As far as I know, it's pretty accurate.
Also, I never had to change the PC time using VEE, I'm not sure if VEE supports that.
