I still have a VEE 4 manual! It states that an invisible line feed character exists after the first 4 lines (the last line does not end in CR), and, it appears in the exclude token example output.
Reiner
Sent: Friday, September 21, 2007 4:12 PM
To: VRF
Cc: William.Drago@L-3com.com; vrf@agilent.com
Subject: RE[4]: [vrf] From String Bug
> > William.Drago@L-3com.com wrote:
> > > Exactly! It only adds a CR when it doesn't find the excluded
> > > chars,
which
> is
> > > very strange. I would consider this a bug especially since not
everyone
> sees
> > > the problem.
> > As a user I would have to also agree that this is a bug. I normally
> > just throw in "
" when reading with token format, though I suppose
> > this would break cases where the string intentionally has embedded LF's.
> > In any case, this has been the behavior for a very long time.
> > I tried it back in version 3 and it worked exactly the same.
> > No easy way to fire up earlier versions here ( perhaps the VEE team
> > can ?) but it is probably safe to say it has always acted this way.
> > I would certainly add my vote to see this fixed-- it has to be
> > something pretty simple so can't be a big deal to fix. And it would
> > be one more minor item out of the way!
> Interestingly this is even documented but not explained.
> Page 513 of the 2004 edition of VEE Advanced Techniques shows an
> example of exactly what we are looking at - that includes the extra LF
> at the end. But the example does not appear to explain _why_ the
> character is there, while it does explain the rest of the behavior in
> great detail.
Aha!
Digging a little deeper ( hey it is a friday !) , it seems that this exact same example is included in the 2nd edition of the User's Guide ( 1992- rev B.00.00, aka VEE 2) , page E-52-- and the extra LF is _not_ shown.
Similarly the VEE 3 "advanced programming" again shows this example without the extra <LF> _but_ from quick experiment
VEE3 did indeed add the additional <LF>.
In VEE 5 manuals the <LF> shows up. I unfortunately don't have the VEE 4 manuals -- anyone have them in electronic form?
So whoever updated the manuals between 3 and 5 at some point experimented, found the extra <lf>, added it to the manuals, but apparently never commented on it.
What the behavior was in 3 and 4 didn't match the manual.
What the behavior was before that may be academic I suppose but I would guess the same.
Still a bug to be fixed so far as I am concerned.
Stan
You are currently subscribed to vrf as: reiner.schlieker@siemens.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
Reiner
To: VRF
> > > chars,
which
> is
everyone
> sees
> > > the problem.
> > just throw in "
> great detail.
Aha!
Stan
> > > chars, which
> is
> > > everyone
> sees
> > > the problem.
> > just throw in "
> great detail.
Aha!
Stan
