[:SOURce]:LBFilter
Supported All Models with Option 1EH
[:SOURce]:LBFilter ON|OFF|1|0
[:SOURce]:LBFilter?
This command enables or disables the low- band filter located in the RF path. Use this filter to reduce
harmonics below 2 GHz.
*RST 0
Key Entry Low Pass Filter below 2 GHz Off On
_____
From: Walker, Richard [mailto:Richard.Walker@Herley.Com]
Sent: Monday, March 24, 2008 7:59 AM
To: VRF
Subject: [vrf] vrf - SPCI command for E8257D - Option IEH?
Vee users,
I have searched the Agilent web site for the SCPI command to activate the IEH option (E8257D – Signal Generator) with no luck. This option is for a below 2 GHz harmonic filter option. Has anyone else run across the SCPI command?
Thanks in advance
Richard A. Walker
RF Automation Specialist, LLC
Cell: (631) 834-6293
_____
The information contained in this message may be confidential and legally privileged. If you are not the intended recipient of this email and its attachments, you must take no action based upon them, nor must you copy or show them to anyone.
Please contact the sender if you believe you have received this email in error.
You are currently subscribed to vrf as: Rufus.Warren@herley.com
_____
[:SOURce]:LBFilter?
*RST 0
_____
To: VRF
Vee users,
Thanks in advance
Richard A. Walker
_____
_____
Thanks in advance
Richard A. Walker
_____
