AW: vrf Active X - GoTo function for moving to a bookmark
Question asked by VRFuser on Nov 13, 2007
This is what I use to put data into bookmarks.  I have 50 book marks in a document and this has worked for the past 2 years without a problem.  I use a .dot file so that I do not have to worry about users modifying the template.
ActiveDocument.FormFields("Text1").result = data
Robert
Robert Rais
Testing and Reliability
Yazaki North America Inc.
HYPERLINK "mailto:Robert.Rais@us.yazaki.com"Robert.Rais@us.yazaki.com
Direct:734-983-6444
Fax: 734-983-6445
  _____
From: Willging, Claudia [mailto:claudia.willging@kriwan-testzentrum.de]
Sent: Wednesday, November 14, 2007 2:12 AM
To: VRF
Subject: AW: [vrf] Active X - GoTo function for moving to a bookmark
Hi Stephen,
I already tried to work with the bookmarks Collection, but I was only partially successful. If you want to use the MoveDown Command, this example might be a help for you. You can chose to move Lines (wdline), characters (wdcharacter) or cells (wdcell) in a table. wdextend means, that the line will be marked (wdmove if not). The count is the number of lines (or cells) the cursor is supposed to move (see attached).
But why don`t you just use the method "replace first". You can place a keyword or a sign in your document and make it in white colour, so that it is invisible. With "replace first" you can replace the keyword with a blank or with nothing and your cursor is where you want it to be.
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
Teslastr. 2, D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
claudia.willging@KRIWAN-Testzentrum.de
>>>>  Klicken Sie doch mal auf unsere Neue Homepage www.KRIWAN-Testzentrum.de  <<<<
Von: Stephen Hobson [mailto:shobson85@googlemail.com]
Gesendet: Montag, 12. November 2007 18:31
An: VRF
Betreff: [vrf] Active X - GoTo function for moving to a bookmark
I am trying to use active x from Vee to move the cursor in word to a particular place in the document. From what I can tell, I have two options; either using bookmarks, or by using the movedown function.
However, I've tried both these options, and I am having trouble with the syntax. Using the bookmark example, with a bookmark named bm1, I am using the following function:
Selection.GoTo(ByRef What, ByRef Which, ByRef Count, ByRef Name);
But when I try filling in the what, count, and name, I get syntax errors. Also I don't know what the "which" means. Can anyone explain to me how to use this function?
I am having a similar problem with the movedown function.
Steve
--- You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
You are currently subscribed to vrf as: Robert.Rais@us.yazaki.com
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
