Hi Warren,
I tried that. Did not work
Simon
From: Pickles, Warren [mailto:Warren.Pickles@tycoelectronics.com]
Sent: 18 July 2007 11:30
To: Simon Parfitt
Subject: RE: [vrf] Saving Object type variable to file
Without having tried it, I wonder what "WRITE CONTAINER x" in a VEE 'To File' object would do?
Sent: 18 July 2007 11:24
To: VRF
Subject: [vrf] Saving Object type variable to file
Hi All
This might be stupid question but is there a way to save a windows object type variable to a file and then reading it back?
I want to save a tree view to file and then read it back.
Simon
This e-mail (including any attachments) is intended only for the
recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message.
Any statement and/or opinion not related to this company's business and expressed in this message is that of the author and does not necessarily reflect those of Icera. This company does not take any responsibility for the views of the author in any matter not related to the company's objective.
You are currently subscribed to vrf as:
To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
This e-mail (including any attachments) is intended only for the recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message.
Treeviews (and treenodes) are not serialisable, unfortunately.
The best you can do is create a data structure that represents the tree (nested record arrays would be ideal) and save that instead.
Cheers
Paul F.
"Simon Parfitt" <parfitt@IceraSemi.com>
Document Marked as Unclassified
18/07/2007 11:56
Please respond to
To
VRF <vrf@agilent.com>
cc
Subject
FW: [vrf] Saving Object type variable to file
Hi Warren,
Simon
To: Simon Parfitt
To: VRF
Hi All
Simon
objective.
You are currently subscribed to vrf as: Paul.Fowler@raytheon.co.uk
--- You are currently subscribed to vrf as: hua_jing@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
