Hi all,
I created a runtime version VXE program using vee pro 7.5 and encounter this after the VXE program finish executed.
The VXE program suppose to close by itself after finish executed.
It works fine when i run program in vee 7.5 and only encounter this when run in runtime version.
How to get rid of this?
Please help, thanks.
It will be easier to look into if you can share the VEE file (or a simpler VEE file which will create a VXE file that gives the error).
