Hello All,
Please ignore the request, i have got it going now. The suffix for the runtime version should be .vi.exe, then its ok.
kind regards,
Intasar
Intasar Khan wrote:
> Hello VRF,
> Looking for help with some trouble executing a Labview application
> program when called from VEE using Execute Program (PC) object.
> When VEE calls a Labview program it works fine, but when it calls a
> Labview program that is just an executable (ie runtime only) then VEE
> throws an error, saying file not found. But i have checked the file
> path and names and all is correct, it just seems to have trouble with
> a Labview program that is just the application.
> Just wondering if anyone had seen anything like this or if anyone had
> any thoughts to what could be the cause?
> kind regards,
> Intasar
kind regards,
Intasar
Intasar Khan wrote:
> Hello VRF,
> kind regards,
> Intasar
Looking for help with some trouble executing a Labview application program when called from VEE using Execute Program (PC) object.
When VEE calls a Labview program it works fine, but when it calls a Labview program that is just an executable (ie runtime only) then VEE throws an error, saying file not found. But i have checked the file path and names and all is correct, it just seems to have trouble with a Labview program that is just the application.
Just wondering if anyone had seen anything like this or if anyone had any thoughts to what could be the cause?
kind regards,
Intasar
