Hello VRF,
Looking for some help with how to close a program using VEE that is opened with the Execute Program object
I open a telnet command shell to COM1 (Putty in my example) with a Execute Program, after a short time the telnet command shell needs to be closed by VEE so a log is created (putty.log) which is then analysed. The tester cannot close the command shell as the programs needs to take logs several times. So i need some way in VEE to close the putty telnet command shell.
any help or advice appreciated,
thanks,
Intasar
thanks,
Intasar
thanks,
Intasar
