> Chapter 4 covers programming, which appears to use "HP-SL", which is
> indeed "different" but appears well documented.
Actually, not that different. HP-SL was the original name for SCPI when we initially developed it for HP internal use. We renamed it TM-SL and gave it to the industry. They immediately renamed it SCPI and then made some minor changes before adopting. A dozen or so instruments made it out under the HP-SL moniker.
I second the panel driver approach. If you open the 8665 driver here:
http://www.home.agilent.com/upload/cmc_upload/All/hp8665a.id
And search down about 20% of the way, you will find the following component:
COMPONENT RF_OFF_ON;
TYPE DISCRETE;
VALUES OFF,ON;
INITIAL OFF;
SET ACTIONS;
SELECT RF_OFF_ON;
CASE OFF;
OUTPUT STRING "POWER:STATE OFF";
CASE ELSE;
OUTPUT STRING "POWER:STATE ON";
END SELECT;
END ACTIONS;
GET ACTIONS;
OUTPUT STRING "POWER:STATE?";
ENTER XSTRING FORMAT "K";
SELECT XSTRING;
CASE "0";
FETCH (RF_OFF_ON)OFF;
CASE ELSE;
FETCH (RF_OFF_ON)ON;
END SELECT;
STORE RF_OFF_ON;
END ACTIONS;
END COMPONENT;
Panel drivers were written in a funky FORTH dialect, but the command strings are pretty obvious.
Jay Nemeth-Johannes (I used to be the project manager of this stuff in a past life) 3420 Riverside Street Rockford, Illinois 61103
(815) 708-0423
(970) 290-9797 (Cell)
www.SmartSensorSystems.com
TYPE DISCRETE;
VALUES OFF,ON;
INITIAL OFF;
SET ACTIONS;
SELECT RF_OFF_ON;
CASE OFF;
CASE ELSE;
END SELECT;
END ACTIONS;
GET ACTIONS;
SELECT XSTRING;
CASE "0";
CASE ELSE;
END SELECT;
STORE RF_OFF_ON;
END ACTIONS;
END COMPONENT;
(815) 708-0423
> Greetings all,
> I've inherited an old program and test setup that uses an H/P 8665A
> synthesized signal generator. The only documentation I can find on the
> Agilent web-site is an old legacy manual that doesn't contain programming commands.
> The only thing I need to do is tell this beast to turn the RF output
> on at the beginning of the program. I've tried every sig gen command I
> can remember with no luck. The commands that do work on this thing are kind of a mix of formats.
> Setting basic parameters like Frequency and amplitude look like
> typical old H/P style commands (FREQ 55.25MHz), but turning modulation
> off and on looks like SCPI (AM:STAT OFF). I've tried all the
> combinations I can think of but always get an error message on the unit saying "Invalid header mnemonic".
> Anyone remember the command for this or have a copy of a manual with
> programming commands?
wandered by www.agilent.com and typed "8665a programming manual"
into the search and found:
http://cp.literature.agilent.com/litweb/pdf/08665-90078.pdf
Chapter 4 covers programming, which appears to use "HP-SL", which is indeed "different" but appears well documented.
have fun
Stan
