Yes, but these sub-functions always end up containing some support code in addition to the UI elements. Would like to minimise code repetition.
From: Schlieker, Reiner [mailto:reiner.schlieker@siemens.com]
Sent: 07 November 2007 16:57
To: VRF
Subject: RE: [vrf] panel size
Well, you can sorta do the same thing by having sub-functions with their own panels, I guess.
Reiner
From: Pickles, Warren [mailto:Warren.Pickles@tycoelectronics.com]
Sent: Wednesday, November 07, 2007 9:34 AM
To: VRF
Nicer still would be if you could have more than one panel for each userfunction - choose which one you want to show when you call showPanel. Then you could query the screen resolution and make full use of the available screen space.
i.e. showPanel(UFName, x, y, width, height, panelName)
Sent: 07 November 2007 14:26
To: VRF
Yes, that would be nice - and scale the fonts used too!
Reiner
Sent: Wednesday, November 07, 2007 12:23 AM
To: VRF
Subject: Re: [vrf] panel size
"...and then size the panel, and size and position each element on the panel."
If only the element's (object's) postion & size in the panel could be specified relative (proportional) to the size of the panel. May be as a percentage of the width & height...
...just my thoughts.
Vinod
----- Original Message ----
From: "Schlieker, Reiner" <reiner.schlieker@siemens.com>
To: VRF <vrf@agilent.com>
Sent: Tuesday, November 6, 2007 10:27:41 PM
The difficulty isn't in resizing the panel, it's making everything on the panel scale with the panel itself, according the the current screen resolution. VEE 8 now allows programmatic setting of object sizes, but I'm not sure if it does position (probably), so you would need to read the screen resolution out (you can use .NET), and then size the panel, and size and position each element on the panel.
Reiner
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
You are currently subscribed to vrf as: reiner.schlieker@siemens.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
To: VRF
Reiner
To: VRF
To: VRF
Reiner
To: VRF
Vinod
Reiner
Do You Yahoo!?
any body know how to control a panel size .... i try to use show panel but ( as you know ) in this case the panel functionally not working and when i use call panel it appeare with a fixed size
note that these panel contain a selection element that wait the user action and all i want is to adapt the panel size with the screen setting
any help
ok
Do You Yahoo!?
