Hello.
I have a PCB structure that I simulated in momentum, and would like to see the far field radiation patterns of this structure for different excitation signals (different amplitudes, phase and frequencies). Is there a way to sweep these excitation signals instead of specifying them by hand for every simulation?
/Shadi Yousef
/Shadi Yousef
https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,39980&_dad=portal&_schema=PORTAL&id=168792&search=&cid=8895&ref=browse
This allows you to setup frequency sweeps in an AC analysis which speed up the post processing a little bit.
