Hi Jochen,
Why do you want to change the logical ID? Does your OS can not solve the resource confliction between USB-GPIB and 8 port serial card?
Old ISA/EISA-gpib-card has switch on the card to set the logical ID to avoid its resource confliction with other hardware. Now all is settled with OS.
Best Regards,
Xiaoying
_____
From: Gallmayer, Jochen [mailto:j.gallmayer@lxinstruments.com]
Sent: Tuesday, July 29, 2008 6:05 PM
Subject: [vrf] How to change logical-ID of USB-GPIB (Agilent)
i´m, using an Agilent USB-GPIB-Konverter 82357B which runs with the Agilent-IO-Libraries 15.
I also have an 8-port serial-card.
When i plug in the usb-gpib then it appears as Logical-ID 15 in the IO-Libraries.
Is there a way to change this number? I remember that in the pci-gpib-cards this value could be changed.
But where to change it for usb?
Thanks for any ideas.
best regards
Jochen Gallmayer
Software-Entwicklung
You are currently subscribed to vrf as: xiaoying_luo@agilent.com
You are currently subscribed to vrf as: hua_jing@agilent.com
Best Regards,
Xiaoying
_____
best regards
Jochen Gallmayer
rufus
_____
From: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Sent: Tuesday, July 29, 2008 5:26 PM
To: VRF
Subject: [vrf] Need Agilent 83640b Programming manual
All,
I haven't been able to find a programming manual for this instrument. Does anyone have a pdf they can send along?
Bill
You are currently subscribed to vrf as: Rufus.Warren@herley.com
_____
The information contained in this message may be confidential and legally privileged. If you are not the intended recipient of this email and its attachments, you must take no action based upon them, nor must you copy or show them to anyone.
Please contact the sender if you believe you have received this email in error.
