MatrixInput behaviour set to true is not allowed for panel view.
Also, in case you may want to use it in future, NextCurve control input does not work with MatrixInput behaviour set to true.
Omer Akbas
_____
From: Losik, Vlad [mailto:losikv@tycoelectronics.com]
Sent: Wednesday, February 13, 2008 6:10 PM
To: VRF
Subject: [vrf] Vee 8.5 bug?
The manual for Vee 8.5 says that graphs now can accept up 250 traces.
Take a look at this program:
try to vary number of traces between 1 and 200 and in between.
On my computer eventually graph breaks.
On panel view it's size changes for no apparent reason, the trace legend no longer matches the traces in graph and some traces appear to be missing.
Can anyone reproduce this behavior? <<multiplot.vee>>
BUG???
You are currently subscribed to vrf as: omer.akbas@arcelik.com
_____________________________________________________________________________________________________________________________________________
Bu e-posta mesaji kisiye ozel olup, gizli bilgiler iceriyor olabilir. Eger bu e-posta mesaji size yanlislikla ulasmissa, icerigini hic bir sekilde kullanmayiniz ve ekli dosyalari acmayiniz. Bu durumda lutfen e-posta mesajini kullaniciya hemen geri gonderiniz ve tum kopyalarini mesaj kutunuzdan siliniz. Bu e-posta mesaji, hic bir sekilde, herhangi bir amac icin cogaltilamaz, yayinlanamaz ve para karsiligi satilamaz. Bu e-posta mesaji viruslere karsi anti-virus sistemleri tarafindan taranmistir. Ancak yollayici, bu e-posta mesajinin - virus koruma sistemleri ile kontrol ediliyor olsa bile - virus icermedigini garanti etmez ve meydana gelebilecek zararlardan dogacak hicbir sorumlulugu kabul etmez.
This message is intended solely for the use of the individual or entity to whom it is addressed , and may contain confidential information. If you are not the intended recipient of this message or you receive this mail in error, you should refrain from making any use of the contents and from opening any attachment. In that case, please notify the sender immediately and return the message to the sender, then, delete and destroy all copies. This e-mail message, can not be copied, published or sold for any reason. This e-mail message has been swept by anti-virus systems for the presence of computer viruses. In doing so, however, sender cannot warrant that virus or other forms of data corruption may not be present and do not take any responsibility in any occurrence.
Omer Akbas
_____
To: VRF
BUG???
Bernd
_____
From: LXI & VEE - JC Park [mailto:jcpark@lxi.co.kr]
Sent: Wednesday, February 13, 2008 09:05
Subject: [vrf] Reducing VEE Runtime loading time.
Hi VRF,
As my VEE program is getting bigger, it takes longer time to launch it on VEE Runtime version. And it doesn’t look beautiful showing the grey-colored launching screen of VEE Runtime version until it is ready.
Any idea will be appreciated, to reduce the VEE Runtime launching time. Or could we just hide the grey-colored launching screen and show other fake image?
JC Park
You are currently subscribed to vrf as: bernd_nebendahl@agilent.com
