Michael,
You could configure the instument's IP in VEE Instument Manager menu. My method simply gives you the flexibility of programatically changing the IP, as I always do.
Either way should work, but if you still have a problem you may send a snippet of your code with the I/O config that you are having problem with, and I can look into it.
-Vinod
--- Michael Ford <michael.ford@comtechpst.com> wrote:
> I am using VEE 8. I/O Lib 14.2. I solved my problem by using
> Sockets, but I would like to know what is wrong.
> * I set up my VEE instrument Manager with an IP address exactly the same as I
> set up Agilent Connection Expert.
> * The Agilent Connection Expert achieves connection, but the VEE Instrument
> Managers gives me the "no instrument or interface found" error message.
> I have already received a VRF reply from Vinod. The difference in his
> example is that he is setting this command in a function object.
> IO.SA1.visaAddress = "TCPIP0::"+value+"::inst0::INSTR"; Unfortunately, I haven't had the time to try this.
> Michael Ford
> Test Engineer
> Comtech PST Corp.
> 105 Baylis Rd. Melville NY, 11747-3833
> Email: michael.ford@comtechpst.com
> Phone: 631 486-4108
> Fax: 631 777-8877
> www.comtechpst.com <http://www.comtechpst.com/>
> ________________________________
> From: Baranski, Detlef [mailto:Detlef.Baranski@pilkington.de]
> Sent: Wednesday, January 09, 2008 10:42 AM
> To: Michael Ford; VRF
> Subject: AW: [vrf] Direct I/O Lan configurations
> Are you using DirectIO 15.0 now ? And what vee version ?
> Or is your problem solved over the years
> detlef
> Von: Michael Ford [mailto:michael.ford@comtechpst.com]
> Gesendet: Donnerstag, 3. Januar 2008 19:32
> An: VRF
> Betreff: [vrf] Direct I/O Lan configurations
> Does anyone have an example of using a Direct I/0 object with LAN (TCPIP).
> I'm coding a new R&S ZVL that does not have a GPIB interface. I would
> like to use the LAN interface.
> I've established *IDN? Responses when using the Agilent Connection
> Expert, but I can't get the VEE instrument manager to recognize this interface at all.
> Michael Ford
> Test Engineer
> Comtech PST Corp.
> Phone: 631 486-4108
> Fax: 631 777-8877
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch ... y=shopping
-Vinod
> Michael Ford
> Test Engineer
> Comtech PST Corp.
> Phone: 631 486-4108
> Fax: 631 777-8877
> detlef
> An: VRF
> Michael Ford
> Test Engineer
> Comtech PST Corp.
> Phone: 631 486-4108
> Fax: 631 777-8877
I’m coding a new R&S ZVL that does not have a GPIB interface. I would like to use the LAN interface.
I’ve established *IDN? Responses when using the Agilent Connection Expert, but I can’t get the VEE instrument manager to recognize this interface at all.
Michael Ford
Test Engineer
Comtech PST Corp.
Phone: 631 486-4108
Fax: 631 777-8877
HYPERLINK "http://www.comtechpst.com/"www.comtechpst.com
