Hello Xiaoying,
thanks for your answer. There is no conflict with the USB-GPIB and the 8 port serial card. Everything works fine.
The only problem is that i have a lot of testexec-sequences which are calling vee-actions. And the actions have as input the gpib-address.
This address is for example "701" (logical-id "7" and instrument-address "1").
Now i have to change all parameters to "1501" what means a lot of work.
Would be easier if its possible to change only once the logical-id for the USB-GPIB.
(Lesson learned: Always set the address via symbol-table and not hardcoded.)
best regards
Jochen
_____
Von: LUO,XIAOYING (A-China,ex1) [mailto:xiaoying_luo@agilent.com]
Gesendet: Mittwoch, 30. Juli 2008 04:56
An: VRF
Betreff: RE: [vrf] How to change logical-ID of USB-GPIB (Agilent)
Hi Jochen,
Why do you want to change the logical ID? Does your OS can not solve the resource confliction between USB-GPIB and 8 port serial card?
Old ISA/EISA-gpib-card has switch on the card to set the logical ID to avoid its resource confliction with other hardware. Now all is settled with OS.
Best Regards,
Xiaoying
_____
From: Gallmayer, Jochen [mailto:j.gallmayer@lxinstruments.com]
Sent: Tuesday, July 29, 2008 6:05 PM
Subject: [vrf] How to change logical-ID of USB-GPIB (Agilent)
i´m, using an Agilent USB-GPIB-Konverter 82357B which runs with the Agilent-IO-Libraries 15.
I also have an 8-port serial-card.
When i plug in the usb-gpib then it appears as Logical-ID 15 in the IO-Libraries.
Is there a way to change this number? I remember that in the pci-gpib-cards this value could be changed.
But where to change it for usb?
Thanks for any ideas.
best regards
Jochen Gallmayer
Software-Entwicklung
You are currently subscribed to vrf as: xiaoying_luo@agilent.com
You are currently subscribed to vrf as: j.gallmayer@lxinstruments.com
You are currently subscribed to vrf as: hua_jing@agilent.com
best regards
Jochen
_____
An: VRF
Hi Jochen,
Best Regards,
Xiaoying
_____
best regards
Jochen Gallmayer
