I am trying to connect a ztec LXI instrument in VEE 9.0.
in the Agilent Connection manager it works fine using the LAN/TCPIP0 connection. it found it with no problem.
the visa string was TCPIP0::169.254.166.9::inst0::INSTR
from the connection manager i can send *idn and get a response back. I can view its web page...
from vee i can't connect to it. I tried copying the connection string directly from the connection expert to vee and i tried using an alias. neither worked.
Ideas?
kevin
Ideas?
kevin
If Connection Expert found it, then VEE should be able to find the instrument without Alias.
