Hello Alex:
I had a similar problem a few months ago, VEE does not like the C, C++ style h files, the process of converting them is not straight forward the first time, but once you do it, is simple enough, depending on the version of VEE you have (prior to 8.0) is a little bit more problematic as prior to 8.0 VEE didnot accepted byte declarations...I suggest you either post your h file or go the vrf archive and search for previous postings...by the way your question repeats itself every two months or so in this list, so you should be able to find some answers in the archive.
Regards
Gonzalo
From: Harwood, Shaun [mailto:shaun.harwood@siemens.com]
Sent: 11/28/2007 12:29 PM
To: VRF
Subject: RE: [vrf] Hi, I'm a new user. --> Problem with C-header file
Hi
I say post the .h file so we can look at it.
Best regards
Shaun Harwood
Process Engineer/Technologist Microelectronics
Siemens AG
Automation and Drives, A&D SC PS 2 MFG
Tel. : +1 (705) 740-7035
Fax. : +1 (705) 741-0466
http://www.siemens.com/automation
Siemens Aktiengesellschaft: Chairman of the Supervisory Board: Gerhard Cromme; Managing Board: Peter Loescher, Chairman, President and Chief Executive Officer; Heinrich Hiesinger, Joe Kaeser, Rudi Lamprecht, Eduardo Montes, Juergen Radomski, Erich R. Reinhardt, Hermann Requardt, Uriel J. Sharef, Peter Y. Solmssen, Klaus Wucherer; Registered offices: Berlin and Munich; Commercial registries: Berlin Charlottenburg, HRB 12300, Munich, HRB 6684; WEEE-Reg.-No. DE 23691322
From: Alexander Lorenz [mailto:alorenz@mail.upb.de]
Sent: Wednesday, November 28, 2007 6:57 AM
To: VRF
Subject: [vrf] Hi, I'm a new user. --> Problem with C-header file
Hello everybody!
I want to import a .dll into VEE. The .dll and .h files came with the driver of a video capture card.
The .h file is written in C (I suppose).
I tried to use the 'improt library'-object.
'Load Lib' reports some errors in the .h file.
1. VEE cannot understand the declaration of a function, when the function is written in more than one line.
2. There is a number of lines of the form:
_MVAPI (int) mvGetBoardInfo (int boardno, INFO_T* pinfo);
VEE cannot interpret this kind of syntax (and I can't eigther).
The author of the .h file has commented this section with
/* resident functions */.
Can you help me?
Alex
Alexander Lorenz
Physikalische Chemie
Universität Paderborn
Warburger Str. 100
33098 Paderborn
Tel. 0177 / 3051324
05251 / 60 2581
You are currently subscribed to vrf as: shaun.harwood@siemens.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
You are currently subscribed to vrf as: gurday@negenex.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.503 / Virus Database: 269.16.8/1153 - Release Date: 11/26/07
9:08 PM
No virus found in this outgoing message.
9:08 PM
Regards
Gonzalo
To: VRF
Hi
Best regards
Shaun Harwood
Siemens AG
To: VRF
Hello everybody!
Can you help me?
Alex
Alexander Lorenz
Warburger Str. 100
33098 Paderborn
Tel. 0177 / 3051324
05251 / 60 2581
9:08 PM
9:08 PM
