Objective is to remote control four instruments through GPIB. Among them an Agilent 34401 Dmm.
- Windows_7 64bit
- The aplication i use, uses Win-Wrap BASIC . Very similar to Visual BASIC 6.
( As far as i know the application is 32bit, not sure if has smthn to do with the problem)
- The interface card i use, is an Agilent 82350b PCI card and the latest version of Agilent IO Libraries Suite 16.3
- Drivers : driver_ivicom_ivic_Agilent34401_1_2_2_0.msi)
In addition for the rest of the instruments (Scope, RFSigGen, SpecAn) respective IVI-COM drivers from Rohde&Schwarz.
IVI class drivers also installed.
Still not having the instruments in hand, i downloaded the Agilent34401_1_2_2_0.msi instrument specific driver just to try to simulate, building a simple interchangeable program following the instructions from the IVI geting started guide for VBasic 6.
http://www.ivifoundation.org/downloads/IVI%20GSG%202011/IVI%20GSG%20VBasic6%202011.pdf
*The problem :* From the very start of the code, it is impossible to create a driver instance using , for example the
Dim Obj As New Agilent34401
error code : ActiveX-Automation: Server cannot create object .
Same situation when i try to create an instance from the other two drivers RsRFSigGen and RsSpecAn.
Untill now:
I have tried to see if the driver is registered in the registry using command promt -> regsvr etc. All seem to be in order.
A more experienced in programming coleague has tried to create some simple scripts too but similar problem occured here too.
Obviously i use the necessary references to the .dll files of the drivers .Not sure though if the 64bit or 32bit sign makes a difference here and how.
Note that i've already tried to reference various combinations of .dll files.
I suspect application's incompatibility to the drivers.
I would be gratefull if someone could suggest me something .
Thanks in advance.
- Windows_7 64bit
Untill now:
Thanks in advance.
I tried both the 32 and 64 editions of Win-Wrap basic and had no luck creating any of our COM objects (including VISA COM). Our drivers are supported in VB6, VB.NET and VBA (excel) Microsoft development enviroments.
Connectivity
