I am writing a ATE SW to control E3641a power supply with labview.
I setup its output at 12V. When it is running the display always shows voltage(12V) and limit current(0.5A) but my customer want it shows real current instead of current limit.
If it is at local status, to change between “limit mode” and “normal mode” just press button of “Display Limit” is fine. The problem is I cannot find any command it works as the function of “Display Limit” button in remote status.
It would be appreciated if anyone can help me out.
Selion
Selion
i have the same problem..
Have you managed to solve the problem?
Cumps
