I have a HP 6032A power supply controlled by the GPIB bus. I have a problem I could not understand it. When I send a command to the first power supply (15V affect voltage for example), it takes at least 10 seconds to get started. After the closing of the output (set to 0, and OFF of the output), if I send a command, the power supply is operating correctly. I have not really found an explanation of this problem. I use Labview 6 for control and the driver HP 6xxx.
Cordially
Cordially
What is your current limit set to? If you have a really low current limit setting, it will take a while for the output capacitor to charge. Please take a look at this and let me know.
