Our code currently does the following:
FREQ xHZ;
FREQ?
We then compare the returned value w/ the set value (and we give a +/- 3Hz window even though we're setting to a MHz step size). Intermittently, the return value does not match the set value. Looking at the PSG, it did NOT error, neither the WRITE SCPI or the READ SCPI failed, and the frequency is the previous frequency. We also tried inserting a *OPC in-between the commands to, hopefully, insure that the first command finished prior to the 2nd but that had no effect.
This hasn't happened when we set both the frequency and power (prior to reading) or just setting the power.
Is there something we should be doing to insure that the FREQ command works?
Our firmware is currently at C.06.15 and hopefully this is okay since it takes an act of god to upgrade here.
FREQ xHZ;
FREQ?
Just realized I misread the post, the +/- 3Hz threw me:
What is the sequence leading up to these commands? You mentioned Steps, what Frequency Mode are you in? Did you set it to List Mode?
Spacecase
Edited by: Spacecase on Oct 10, 2012 3:36 AM
