Hello! I need some help with changing properties for a box before activating it.
For example. I need to disable a drop-down list by changing its properties to "EnableEditing - Flase" before activating it. So I need some kind of a box sending a commando to the drop-down list telling it to change its properties without me needing to do it. Does a box like that exist or can I accomplish it in any other way?
If you need more explanation I will gladly try to tell you more. Thanks!
Hope this helps.
-mk
