Anybody knows the SCPI command to launch and read the Peak-table data from E4404B (ESA) Spectrum Analyzer?
Akato
Edited by: akato on Apr 15, 2013 4:57 AM
Akato
On the ESA, you can turn on the Marker Table using CALC:MARK:TABL:STAT ON. In order to read the amplitude value of marker 1 for example, you would have to send CALC:MARK1:Y? To read the frequency value of marker 1, send CALC:MARK1:X?
Newer Agilent analyzers use the READ:SAN0? Command, which would return all marker amplitude and frequency values that are in the marker table.
Regards -
