Hello all,
for some reasons we plan to build a long wire fixture.
That means
- we do a fixed wiring from *all* system resources to a connector
- We need a wiring "from this connector" to the uut(s)
- program generator does not have to pay attention for conflicts between perso pins and probes
How can this be achieved?
Thanks, ABinsack
That means
Thanks, ABinsack
to avoid p-pin conflicts you can either choose a wireless fixture (pcb based), or long wire fixture - but not many fixture vendor do make a lonmg wire kit for the 3070 now. Plus there are some height limitations if you are using in conjunction with board handler etc.., then this may not be possible.
But assuming that you still require long wire - then on the 3070 development software there is option for this, just select the 'simplate' option does mean long wire.
If you look to the 3070 manuals, you will find a lot of references to Simplate,
Simplate Express means 'short wire'
hope this information is helpful to you
best regards, Jon
