Is there a way to capture the demodulated bitstream in a file in order to calculate the Bit Error Rate (BER)?
For example, I'm building WiMax signals with different levels of AWGN using Agilent's N5182A VSG and Signal Studio with a known dataset. I can then capture the signal's IQ data in a CSV file, import this to the 89601A software and successfully demodulate the WiMax signal. In the 'Ch1 OFDM Sym/Errs' window I can see the demodulated bits for each of the data bursts, along with the pilot bits, in the WiMax Signal but is there a way to capture this in a separate file?
The demodulated bits are the “trace data”.
This trace can be saved to a file using File, Save, Save Trace.
This trace can be copied to the clipboard using Edit, Copy.
An external program can also read this trace via the API.
Regards -
