VNA calibration procedure for a test cable
Question asked by VanH on Oct 29, 2012
Latest reply on Nov 2, 2012 by Dr_joel
Hi Agilent Technical Support Team,
I have a question regarding about calibration of a test cable using the Agilent PNA network analyzer, model N5224A with the mechnical Cal kit 85056A. I want to find out  the
accurated procedure to calibrate a 3 inches long semi-rigid PCB solderable at one end and the connector on the other end is a 2.4mm male connector. The center frequency is at
26GHz.
Thank you for your help!
Van
