I'm trying to measure voltage arrays for a 6812B power source using the command MEAS:ARR:VOLT?
When I send this command followed by a read array 4096, it only seems to work once then it is stopped by an error. It always works after my VEE program has been re-started, but I can't seem to get it to work on a cycle. I would like to display the array values every minute if possible.
Does anyone know how to use this command to measure the voltage array on a specified time cycle?
Greg
Greg
What do you have the measurement interval and the points offset set to? Can you give me details of the error?
Thanks.
Matt
