simulated and measured result
Question asked by kamaldeakin on Mar 25, 2013
Hi!
I have fabricated a Schottky diode based rectifer  circuit for RF but the simulated and measured result is not closer. I am wondering about the layer setting during simulation.
in fabrication: I have used two layer PCB board to make my device. The bottom layer works as ground plane and top layer is milled as the layout. The bottom layer is a continuous finite copper plane. The size of the board is around the size of the layout.
Would you please help me regarding to layer setting during the simulation??????????
If yes please send me message I will contact you.
Thanks in Advance!!!!!!!!!!!!
