Hi All,
Using Simulink drivers, i am able to receive a packet [from a far/distant site, where LTE packets are being generated]. Below is my setup
LTE generator [downconverted RF packets] --> converted to Ethernet packets ---> Simulink --> Agilent[[89601B-BHE or 89601B-BHD] ] VSA Software [only software NO HARDWARE]
Please note the generation [LTE generator] is happening miles away and it is being transported in Ethernet packet format and fed into simulink and then to Agilent VSA driver.
Since VSA is NOT run on trigger basis [please note it is run on free-run basis], is it possible to decode LTE vector through LTE [89601B-BHE or 89601B-BHD] [standards-based signal evaluation and troubleshooting tools]
Thanks
Madeline
Edited by: Madeline on Mar 11, 2013 12:39 PM
Thanks
Madeline
Thanks for your quick reply. there are 2 points here
1. VSA can analyze the signal. i agree [as per your statement].
2. can the LTE specific modules BHE/BHD can decode the signal under free-run trigger mode ??
Thanks
MadeLine
http://wireless.agilent.com/wireless/helpfiles/89600B/WebHelp/89600_CSH.htm#../Subsystems/lte/content/lte_dlg_time_analysisstartbound.htm
Thanks for all your replies. it all cleared my doubts.
Regards
MadeLine
