Data Link and FieldFox Connection Time-Out
Question asked by Tim on Apr 2, 2013
Latest reply on May 13, 2013 by am95405
It appears to me that when set IF BW lower than 300Hz, Data Link software would either change the IF BW to 300 Hz or fail to connect due to time-out. The go around is: save the sweep first then use the Data Link to load the file. By doing so you will find Data Link will fix the IF BW to 300 Hz even the actual IF BW of the recorded sweep is lower.
I suspect Data Link may have been made for N9923A with older firmware and the lowest IF BW was 300 Hz.
Any clue on this and a future Data Link update may get this adjusted?
Edited by: Tim on Apr 3, 2013 1:02 PM
