Hello every body,
I am using the HP 4280A 1MHz C Meter/C-V Plotter for C-V and C-t measurements.
The HP 4280A 1MHz C Meter/C-V Plotter takes the setup measurements but doesn't sending the measured data to the computer.
I don't know why!!!
I have used the necessary instructions to make the transfer data mode and reading the output data but it appears an error instruction in reading. may be the command is not adequate. I don't know what's it in all cases.
But I need your help. Please.
I don't know why!!!
