I have a synthetizer Agilent E8257D (with options : UNY, 540, 1E1, 1EU and IEH) and I would like to drive it with IVI (with LabVIEW).
How can I enable (and disable) the option 1EH (improved harmonics below 2 GHz / setting of low pass filter). I think, this function doesn't exist in IVI.
I have the same question for this option : "optimize SNR".
Benjamin
Benjamin
I finaly drive the synthetizer in VISA because the IVI command-set is poor.
I can now set all the options that I need sush as the 2 I asked few days ago except another one : "optimize phase noise below 250 MHz (RF path [normal] OR Low phase noise below 250 MHz)".
I didn't find the command in the "SCPI command reference" pdf file, someone knows the command ?
Benjamin
