"Failure acquiring single loop FracN LO lock"
Intially I had a Firmware error but have cleared that.
Is this somthing that can be fixed at the Cal house?(software fix without componet change)
Thanks for the help!
Bardo
Bardo
It appears that there is a problem with the A12 Synthesizer Assembly. An Agilent service center can repair your instrument.
Alternatively, for customers that maintain their own equipment, please refer to the section in the PSA Series Spectrum Service Guide called “Verifying the A12 Synthesizer Assembly”. The PSA service guide is orderable as E4440AU-0BW.
Regards -
