User is getting problem when he tries to run the BLDL software after instal
Question asked by rakesh on Apr 20, 2012
If user is getting the problem after installation and while running(screen shot ) attached.Then problem may be related to .NET framework, please follow the below suggestion in order to resolve this problem:
First Procedure :Uninstall Dot net framework 2.0 and reinstall it.
After doing this if everything works then good
Otherwise do this also.
1.     Open two windows explorer
2.     In first open this path C:\WINDOWS\assembly (GAC)
3.     And in  second open this path C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
4.     Drag and drop System.EnterpriseServices.dll from second path into first path.
5.     Check again if everything works properly or not. If not follow step 6 also.
Drag and drop System. EnterpriseServices.Wrapper.dll from second path into first path
