vrf Modify Header/Footer in MS Word
Question asked by VRFuser on Apr 11, 2001
Dear Mr.Bonino,
We have the same problem.
A collegue of mine uses To/From DDE Transactions and MS Word's bookmarks to
write in the document, but it's impossible (for us) to write at the same
time in the Header/Footer and in the Body.
I haven't tried the ActiveX way...
Probably we have to :
*     Open the document (Execute Program),
*     Open the Header (with ActiveX Commands)
*     Reading the bookmarks presents in the Header (To/From DDE)
*     Modify the bookmarks (To/From DDE)
*     Close the Header (with ActiveX Commands)
*     Putting datas in the body (To/From DDE)
*     Save the document
*     Close MS Word
Best Regards
Ruggero RISSONE
TELECOM ITALIA LAB
User Equipment Qualification
Instruments Center
Via G. Reiss Romoli 274 - 10148 Torino (ITALY)
Tel. +39-011/228.5145
Fax. +39-011/228.6200
GSM +39-0333/68.66.742
e-mail: Ruggero.Rissone@tilab.com
> From:      Rob Bonino[SMTP:rbonino@comtechpst.com]
> Sent:      luned 2 aprile 2001 10:47
> To:      vrf@lvld.agilent.com
> Subject:      vrf Modify Header/Footer in MS Word
> Todays problem is sending data to a MS Word document.  Does anyone have
> examples with using fields (not the way they do it in the 'vee' examples)
> I am trying to also search & modify the header of a MS Word Document
> through
> the 'vee' program.  I have Visual Basic code that is a little different
> than
> what Vee accepts and can use.  Any help or comments would be greatly
> appreciated.
> Rob Bonino
> This is the "vrf" maillist, managed by Majordomo.  To send messages to
> this maillist, just email to "vrf@lvld.agilent.com".  Subscriptions and
