Is the IVI-COM drivers are compatible with Qt\ Mingw ? or only with VisualStudio ... ?
is anyone has an example with Qt\ Mingw ?
regards,
Michael
regards,
Michael
I'm having the same question. (Using IVI-COM using Mingw).
I already performed several searches on the internet, but I couldn't find someone that has used IVI-COM in combination with Mingw.
Did you already find a solution for this problem in the meantime?
Best regards,
Joro
