Are you aware of devices or devices I can configure as shown notionally in the attached drawing?
Needing to measure 220VAC 3ph on 15 different inputs and select input and report voltage RMS via Ethernet or USB to the test controller.
Any hints appreciated.
thank you
thank you
Maybe a solution would be to use an USB I/O box controlling a set of relays connecting to a measuring device like a DMM giving you the values needed.
