Hi all !
From last month I have this issue with io library suite 14.2:
Every time I turn on or reboot pc, IO Library suite ask for msi installation file path and then it install again every time.
I tried to reinstall all the suite but nothing change.
I attach a screenshot with the error appearing at boot. Anyone having similar issue ? It's annoying to wait the installation and it lock all other programs to start until it finish to install
Thanks for help and have a good day
Greetings, Devis
Greetings, Devis
In my memories, I will get that error if I install the software from network drive. Did you put the IOLS installer in local hard disk before installing?
Hopefully this microsoft link will be useful for you. [http://support.microsoft.com/kb/258847]
-mk
