Dear All, I have a 54831D O-scope and for now the fast way to communicate with it is via Rs232 port. I have a NULL MODEM cable that I tested it between two computers and it works but I tried to send commands to the O-scope through the RS232 port but no answer from it. Is the O-scope has a working RS232 protocol for exchanging commands? because the manual says the port is only used for printer etc .... ?
I use Ubunto Linux as OS in the PC box.
Thank you, rachid
Thank you, rachid
Al
