Leveled power at 50 MHz up to +21 dBm
Frequency range of 10 MHz to 18 or 26.5 GHz
preferably internal scalar pulse with required scalar rear connectors.
I think the only one that's going to get you there is the E8257D. Option 007 - analog ramp sweep - gives you the outputs you need for the 8757D. The power level at 50MHz is pretty high at +21dBm. Option 521 gives you a high power 20GHz frequency range but the output power is spec'd at +19 at 50MHz if you turn the low pass filters OFF (+16 with them on as default). It gets up over +24dBm over 250MHz.
SK
