I have requested "N5391B I²C and SPI Protocol Triggering and Decode for Infiniium scopes" trial 14-ay license. It works but I can't shrink memory depth in "Acquisition Setup" menu. Maximum allowed value is 10.25Mpts but I want to make longer sequence.
Is this trial license limitation or something else ?
P.S.
oscilloscope is MSO9404A with option500 (500 mpts memory).
P.S.
You don't indicate anything else about your setup, but if your data rate is slow, you can reduce your sample rate, which will increase the amount of time that gets processed. If your clock is 10MHz, for example, you can reduce your sample rate to 200MSa/sec, or maybe lower. A multiplier of 10 to 20 should be enough.
Experiment with this and report back, please.
Al
