I'm using the sample code "Diode Test" provided for E3631A. I'm able to send commands to the E3640A successfully. However, on inquires, for example "Meas:Curr?" I get a VI_ERROR_TMO (80040015). Please help!
Below is partial code:
With Pwr
.WriteString "Syst:Rem"
.WriteString "*RST" ' Reset the power supply
.WriteString "*CLS" ' Clear any error messages
.WriteString "Curr " & Str$(Range("E2").Value) ' Set current MaX To 1amp
For i = 5 To 15
reply = Cells(i, 1)
.WriteString "Volt " & Str$(Cells(i, 1))
.WriteString "Output on" ' Turn on the output
Pwr.WriteString "Meas:Curr?"
delay (0.5)
reply = .readstring
.WriteString "Output off" ' Turn off power supply
With Pwr
For i = 5 To 15
reply = Cells(i, 1)
delay (0.5)
reply = .readstring
