Hi, I am using the N5392A Ethernet compliance test application and would like to perform the jitter tests. However it requires having the transmit clk (TX_TCLK) input into channel 2 on the scope, and with the PHY I am using this clock is not brought external to the chip. How can these measurements be made in the absence of this clock?
thanks
thanks
Al
