I realize that when the 33522A is powered on, it took very long for the LAN connection to establish connection with PC. Iis different from using GPIB whereby the connections are established very fast.
This will be a problem for production because the operator might not know there is a wait time for this LAN establishment and start running the tester. This will make the unit tested fail. Do you have a way to make this connection faster for 33522A?
