Hi, i am trying to communicate via GPIB to an instrument with Measurament Studio and the Agilent 82357B .
Here is what i have done:
Installed Measurament studio
Installed NI 488 drivers
Installed NI Visa drivers
Installed Agilent Libraries
Enabled 488 Support on Agilent Connection Expert
Enabled Tulipvisa.dll in NI Automation Explorer
Then I tried to use a NI example for visual studio (Simple Read Write in C#) but when i try to write something via GPIB it says: Nonexistent GPIB interface.
I can see the GPIB in the Automation explorer and in the agilent connection expert, If i use NI Labwindows CVI i can communicate via GPIB without any problem.
Any hint?
Thank You
Any hint?
Thank You
Also, is this 32-bit or 64-bit Windows? 32-bit/64-bit/AnyCpu app?
