Dear All, I was adviced by Al to open this thread so probably I found someone who worked on controlling An agilent scope (for me is 54831D) from a Linux box. The LAN I/O library in Agilent website exists in windows only. The solution is to use sockets TCP/IP communication that I worked on before but if someone has ready code it will be faster. The other alternative is to have the windows C libray code so that I can migrate it to Linux.
Thank you, Rachid
Thank you, Rachid
Rachid
